- This topic has 11 replies, 5 voices, and was last updated 7 years, 9 months ago by
Mieras.
Example:
I have tag “Paracetamol” on 174 pages.
When Download Manager Plugin is turned off and open http://www.mysite.com/tag/paracetamol/ i see list of 174 pages. (correct)
When Download Manager Plugin is active open http://www.mysite.com/tag/paracetamol/ i see info “no post to show” (incorrect)
My theme is Newspaper 8.7
Tom
I have the same issue 🙁
Hi,
Please send the Login information in a private reply. Then we shall check the issue.
Thank you.
Hi,
i can’t send private reply. I already tried 3 times.
Tom
Hi,
off course I checked “Set as private reply” (i tried many times on different PC’s), but when I click “submit” my answer does not appear.
Is it possible to send WP login data in a different way?
Thank You
Thomas
The tags are displayed correctly. Thank you very much. Can you tell me how you fixed it? I am afraid that the problem will come back after the next update of the plugin.
Thank You
Tom
Hi,
Unfortunately, the problem with the tags has returned. Could you tell me how you fixed this last time ?
Thank You!
Hi,
Please open /plugins/download-manager/libs/class.Apply.php
Then find and remove:
add_filter('pre_get_posts', array($this, 'queryTag'));
The topic "Tag's problem" is closed to new replies.
