- This topic has 5 replies, 3 voices, and was last updated 4 years, 7 months ago by
William Camargo.
Hi Support DM,
I am using the onedrive extension, but I am having a problem with the connection between Azure App Registration and OneDrive API Credentials in WPDM.
I already got the Client ID and Client Secret, but I am not sure if I am selecting Redirect Url in the correct way.
I have tried to use your documentation (https://www.wpdownloadmanager.com/download/wpdm-onedrive/) , but it is not exactly equal to the steps that we have currently in the portal azure.
Could you guys help me with this problem?
https://drive.google.com/file/d/1W_luMXxQ002H8_FFHdXIGpbfna8OYYpT/view?usp=sharing
This topic was modified 4 years, 7 months ago by
Rogerio Botelho.
Hello @rvsilva,
Could you please provide more details about the issue you are experiencing? Also let me know what have you added as the redirect url?
If possible please give temporary admin access and Client ID and Client Secret in a private reply.Then I could be able to help you quickly
Thanks
Please Enter redirect URLs as below:
https://websupport.cdbsolutions.com.br/wp-admin/post.php
https://websupport.cdbsolutions.com.br/wp-admin/post-new.php
in here:
and in your site add https://websupport.cdbsolutions.com.br/wp-admin/post-new.php like this:
I hope it will fix the issue.
Thanks
Hi Tanvir,
Thank you for your reply, we did what you recommended and it worked for a personal account, but we had a problem with some permissions about directory that are able to allow only with admin access in the Graph Permissions. We did not understand why this happened because we are using an account that does not have any conexion with other accounts, so in this case it should be the admin account. Do you know why I did not have permission to allow Directory Graph Permissions?
In the other test, we tried to use a corporate account (with the same configuration that we did in the personal account) that gave us an error, when we tried to get the file in the WordPress > Download > Add New > Select From Onedrive.
We tried to change some options in the Portal Azure, but we did not have success. We think that could be a missing of some permissions that our company needs to give to us.
We are not sure about it. Could you guys confirm if is it or something else?
Another question is about the direct download. When we connected with a personal account we did a test by clicking on the download button to get the file that we uploaded, but when we clicked, we were redirected to a microsoft login page, and we do not want it. What we would like to have is when the user clicks on the download button, automatically beginning the download without redirections, without login in Microsoft, and keeping in the same page of our website. Do you know if is it possible to work in this way? (Note: We think that this is possible with the Graph Permissions, but again, we are not sure about it)
And the last question, we are thinking of buying the special pack version, and we would like to know if this pack would increase the basic functions that we have in the conexion with OneDrive, download reports and layouts paths?
Best regards,
Hi Tanvir,
Did you see the message above?
We need this information to continue our project.
Best regards,
William Camargo
The topic "Problem sync WPDM with OneDrive" is closed to new replies.
