- This topic has 8 replies, 2 voices, and was last updated 5 years, 8 months ago by
Ron Barack.
Everything else seems to work, but audio.currentTime always resets to 0.
It seems like the headers are not correct in the HTML containing the stream…
Has the problem been solved? let me know, if possible, share your file URL too
thanks
No, problem is not solved. The Javascript wants to set currentTime, but this doesn’t seem to work of the HTML Headers are not correctly set. I’ve tried to modify what settings I could, for instance, to make the download restartable, but nothing seems to make any difference.
Thanks in advance for any help!
I don’t need to provide a bug on my site, the bug is easily reproducible in your web site.
Look at the video in https://demo.wpdownloadmanager.com/wpdmpro/download/video-player-play-only/
While the video is playing, you should be able to jump ahead or back using the progress bar. But the video just keeps on playing.
This is slightly different than the behavior for audio, which resets to zero, but I’d be surprised if this is not just an effect that the different players.
The bug seems not to occur on Firefox, but on Chrome and Safari.
This night be a useful post when trying to address this bug; https://stackoverflow.com/questions/45805177/chrome-cant-fast-forward-firefox-can-display-mp4-file-with-php
Thanks in Advance,
Ron
I have also noticed that when I select “Open in Browser”, the download does not play.
I’m uncertain now if this is being acknowledged as a bug and will be fixed in some future release, or if I am just being ignored.
I shall try to update about this soon
thanks
Hi,
If your video download is public, please attach the video from the media library, then it will work better, we are working on it updating the feature
thanks
The topic "Audio Player – Progress bar not working (rewind/fast forward)" is closed to new replies.
