- This topic has 13 replies, 3 voices, and was last updated 3 years, 3 months ago by
Shahjada.
How does the Access Control add-on works?
I just purchased the add-on and when I type in the user email to be given access, it loads forever without returning the user to be selected.
Can someone please explain what I a doing wrong?
Please make sure that you are using the latest version of wpdm and all the addons of wpdm that you are using in your website.
Then if the issue persists, please check if php version of your website is minimum 7.4 . After that You may need to run a conflict test on your site to detect what actually causes the problem. if there are any conflicts among the installed plugins. To troubleshoot the issue, please deactivate other plugins except for WPDM with all addons of WPDM if you are using and check if the issue still persists. If that solves your problem, activate the plugins one by one, and continue checking the issue. In this way, you will be able to detect which one causes the problem.
Let us know for further assistance.
Regards
Tanvir
I have tried all of the above and none work. don’t you offer technical assistance?
I am behind on schedule and I can’t seem to get it to do what I want.
If you cannot resolve my problem, I want my money back.
Every plugging I have ever purchased provided support but you guys don’t.
Buying a plugin that doesn’t work and support not being provided is a waste of money.
Please provide temporary admin access in a private reply to check the issue further.
Regards
Tanvir
Please provide me admin access. I am not able to view the plugins page as well as any settings of your website
regards
Sorry about that. I have now made you an admin
Any updates?
Hello Liberty,
Sorry for the delay.
From your website I have found that you are using an older version of WPDM advanced access control.
Please update it to the latest version 3.2.9
I hope the issue will be solved.
Regards
Tanvir
I have updated the plugin and the problem is still the same. nothing changed.
If this isn’t going to be resolved, please I need my money back.
The topic "WPDM Advanced Access Control add-on loads forever without returning users" is closed to new replies.
