Save settings problems
Viewing 3 posts - 1 through 3 (of 3 total)
Oct 25, 2018 at 9:44 pm
#88673
Member
Emanuele
OP
I have downloaded and installed WPDM (free) plugin and i tryed to configure, but:
1) in “update” tab i inser my credential to login and press save setting it goes on “working” but doesn´t save
2) I want configure reCAPTCHA : i insert the 2 parameters and “save settings”, but it goes on “working” but doesn´t save (i use the api key for another plugin and it works)
3) i want configure and use the “google drive addon”: i insert the Api and ID and save settings, but it goes on “working” but doesn´t save.
So 3 diferent situations but the same problem.
Ideas?
Oct 27, 2018 at 1:15 pm
#88721
Member
Emanuele
OP
Nobody hat this problem?
Nov 7, 2018 at 8:37 am
#89171
Moderator
Shahriar
Staff
Hi,
Sorry for the delayed reply.
If you are hosting on Siteground add following rule in your .htaccess file to fix the saving issue,
<IfModule mod_security.c>
SecFilterRemove 001868
</IfModule>
Otherwise please send temporary wp-admin login info in private reply.
Thanks.
The topic "Save settings problems" is closed to new replies.
