Problem with using plugin in several WP-Installations
Viewing 3 posts - 1 through 3 (of 3 total)
Apr 12, 2013 at 9:21 am
#5577
Member
YannVDC
OP
Hello!
I do have 10 seperate WP-Installations which are all located in a central directory named “websites”. The single WP’s are then in subdirs like “domain1.com”, “domain2.com”, … etc. All WP-tables are in the same database, but each installation has it’s own tables, I didn’t use the standard “wp_”, but “d1_” for domain1, “d2_” for domain2, ….
I was looking for a simple download manager tool and found this plugin. I installed it on one domain and uploaded some files. Everything worked really fine and smoothly.
Now I installed it on a second domain and there I was very suprised, when it showed me a list of already existing downloadable files. Well, all the files from first installation. Even when I delete a file in installation nr 2, it disappears in the first installation.
It seems that both installations exactly the same data-tables or other settings. How can I change that? The websites are maintained by different users and I don’t want them to be able to handle with downloads from other users.
Hope anyone can help me.
Best regards
Yann
Apr 12, 2013 at 11:01 am
#5581
Member
YannVDC
OP
Ah, now I saw it. Download-Manager creates a table that is independent from WP, now I could solve it 🙂
Apr 13, 2013 at 10:06 pm
#5621
Keymaster
Shahjada
Staff
The topic "Problem with using plugin in several WP-Installations" is closed to new replies.
