Problem with icon
Viewing 20 posts - 1 through 20 (of 20 total)
Jul 15, 2015 at 7:47 pm
#31740
Member
believer
OP
If I install the plugin, no icons are displayed in my theme. How can I solve the problem?
Thx for answer
believer
Jul 16, 2015 at 1:54 pm
#31775
Moderator
Shahriar
Staff
please give me your URL to check.
Jul 16, 2015 at 4:58 pm
#31782
Member
believer
OP
http://www.gospel-life.de
the WPDM is not installed
Jul 17, 2015 at 5:06 am
#31791
Keymaster
Shahjada
Staff
then please also give me temporary wp-admin login info in a private reply, so that I can test it in your site.
Jul 19, 2015 at 7:18 pm
#31835
Member
believer
OP
This reply has been marked as private.
Jul 20, 2015 at 4:07 pm
#31859
Member
believer
OP
Could you ever find out the error?
Jul 20, 2015 at 4:38 pm
#31861
Member
albert
Same problem here!
http://wp.ugdc.re.it/
Theme is Clever Course, from GoodLayers: if I disable the WPDM, everything works great. I also tried re-installing WordPress with plugin installed, but still icons are not showing if WPDM is activated.
Jul 21, 2015 at 2:00 pm
#31906
Member
albert
Is anybody there?
Do you have any solution to this issue? Or are you just ignoring it? 😀
Jul 23, 2015 at 7:07 am
#31935
Member
believer
OP
@Shaon: Could you find out anything?
Jul 25, 2015 at 8:47 am
#31996
Member
albert
Is this the support you’re providing? No answer for DAYS??
Come on: you can do much better than that
Jul 25, 2015 at 5:11 pm
#32020
Moderator
Shahriar
Staff
@believer, it was because your theme was using old version of font-awesome, I’ve disabling font awesome from download manager and now icons are showing fine in your site.
@albert
, find and remove wp_enqueue_style('font-awesome', WPDM_BASE_URL.'font-awesome/css/font-awesome.min.css'); from functions.php
Jul 25, 2015 at 8:06 pm
#32023
Member
albert
That solved my issue.
Thanks a lot
Jul 26, 2015 at 5:46 pm
#32031
Member
believer
OP
Great. Works.
Thx
Jul 29, 2015 at 8:10 am
#32113
Moderator
Shahriar
Staff
If you happy with the plugin, please give us a 5* here https://wordpress.org/support/view/plugin-reviews/download-manager?rate=5#postform when you get some free moments, It will be a great inspiration for us :).
Aug 31, 2015 at 4:13 pm
#33441
Member
believer
OP
Hey Shaon, after update the DM I`ve the same problem. Where can I disable font awesome from download manager? Or what shall I exactly do for the future?
Thank you for help!!!
Sep 3, 2015 at 5:48 pm
#33650
Moderator
Shahriar
Staff
In function.php, line #1517, please remove the line wp_enqueue_style('font-awesome', WPDM_BASE_URL.'font-awesome/css/font-awesome.min.css');
Sep 8, 2015 at 7:50 pm
#33844
Hi Shahriar,
I am also having the same issue with the fontawesome icons appearing.  Can you show me how to fix this?
Ryan
Sep 9, 2015 at 8:43 am
#33900
Member
Tauhid
Please go to download-manager->functions.php file, find out wp_enqueue_style('font-awesome', WPDM_BASE_URL . 'font-awesome/css/font-awesome.min.css'); and remove or disable the line.
Sep 9, 2015 at 3:39 pm
#33914
Are you referring to wpdm-functions.php?  I can’t find functions.php under download-manager.
Sep 9, 2015 at 7:07 pm
#33939
Keymaster
Shahjada
Staff
Yes. it is wpdm-functions.php in pro and functions.php in free.
The topic "Problem with icon" is closed to new replies.
