How to add a inbuilt audio player to audio type downloads.
Viewing 2 posts - 1 through 2 (of 2 total)
Feb 25, 2022 at 7:41 am
#168721
Participant
Kaveen Amarasekara
OP
Hi, i am currently building a music store website with your plugin. All are fine. But i want to intergrate an audio player to play my files inside website.
Is there any method do it without or with a simple plugin or coding.
Feb 25, 2022 at 8:57 am
#168725
Spectator
Tanvir
You have to use [audio_player] template tag in page template to show audio player.
As you are using free version you can’t edit templates tag directly.
In the free
You just need to follow this:
1. Copy page-templates directory from /plugins/download-manager/src/package/views directory to your active theme directory.
2. Make a new directory as download-manager in your active theme directory.
3. Now remove all files from {active-theme}/download-manager/page-templates except the template files you need to update.
4. Update template file(s) in {active-theme}/download-manager/page-templates directory as per your need.
Thanks
The topic "How to add a inbuilt audio player to audio type downloads." is closed to new replies.
