FILE SETTINGS AND GENERAL SETTINGS NOT WORKING
Viewing 7 posts - 1 through 7 (of 7 total)
Oct 22, 2025 at 9:12 am
#209191
Participant
sara Cicchinelli
OP
Hello, I’m having some issues. I have downloaded the 3.3.29 version and the general settings of the plugin are completely empty General settings not working and when I try to modify the uploaded file settings, nothing happens file settings not working I would like to set privacy options for some files so that only specific user groups can access them. However, this is no longer possible because, in the “Edit File” screen, all the settings have disappeared — there are no options available anymore.
Could you please check if this is a bug or if there’s a new way to configure file permissions in version 3.3.29?
Oct 22, 2025 at 9:17 am
#209193
Moderator
Nayeem Riddhi
Staff
Hello sara Cicchinelli,
Hope you are well. And sorry for the inconvenience. I think it may have a conflict between your plugins or theme. You can disable one by one other plugins for testing if there any conflicts. you may also switch theme to another for checking. if possible, please, give your temporary wp-admin login details in a private reply for checking the issue.
Please kindly check and let me know.
Thank you and kind regards
Oct 22, 2025 at 9:27 am
#209196
Participant
sara Cicchinelli
OP
This reply has been marked as private.
Oct 22, 2025 at 10:10 am
#209199
Participant
sara Cicchinelli
OP
have you checked the issue?
Oct 22, 2025 at 10:45 am
#209200
Moderator
Nayeem Riddhi
Staff
Shall i check enabling/disabling plugin or switching theme for checking if there any conflict? Please kindly check.
Thank you
Oct 22, 2025 at 2:11 pm
#209204
Participant
sara Cicchinelli
OP
sorry, I already checked but i couldn’t find any conflict. What to do now?
thank you for your support
Oct 22, 2025 at 3:10 pm
#209206
Moderator
Nayeem Riddhi
Staff
It is working properly from our testing site. The issue also not claiming by other users. Can i check the issue for enabling/disabling plugin or switching theme? Please kindly check and let me know.
Thank you and regards
You must be logged in to reply to this topic.
