Box.com Explorer plugin does not appear to work
Viewing 3 posts - 1 through 3 (of 3 total)
Jun 15, 2017 at 5:24 pm
#59129
Member
Mark Bender
OP
I have performed a clean install of WP Download Manager and added in the Box.com plugin which is the reason this product is on our radar. However, when I install and activate the Box.com plugin, it does not show up in the ‘Settings’ of Downloads. Google, Dropbox and such appear to work fine. It’s just Box.com. Any guidance on what is happening or what I might be doing wrong?
I’m on the latest release of your software, & WordPress 4.8 running Woffice theme. I have nothing else hooking into Box.com.
– Mark
Jun 15, 2017 at 8:35 pm
#59146
Member
Mark Bender
OP
I took a look inside the file ‘wpdm-box-com/wpdm-box-com.php‘ and I noted that there is quite a bit of the code commented out preventing any config on the settings page. I think you have the wrong package uploaded to your website.
Line 22 – remove comment
Line 51 – remove comment
Line 56 – remove comment
Line 60 should be edited to read ‘?page=wpdm-box-com
I’ve corrected all the above and it now appears to work though I haven’t really gone too far into the options yet.
Attached is the corrected php file version 1.1.0 in case anyone wants to review it.
Jun 28, 2017 at 8:23 pm
#59665
Keymaster
Shahjada
Staff
Thanks, we shall check and update this.
The topic "Box.com Explorer plugin does not appear to work" is closed to new replies.
